sg,
Now that I know the rest of the story it makes more sense..
If that was the original cell installed in 2014, then I agree with you that the cell is most likely bad... The 700 is rated for a 12K pool.. The problem is they rate cells when running at 100% output and 24/7. This is why we always recommend a cell that is at least 2 X the volume of your pool.
If you run the pump for 8 hours and have the cell set for 100% output, it should increase your FC by about 2.5 ppm per day... This is great if your pool uses less than 2.5 ppm per day, but the average usage is 3 to 4 ppm per day.
Your new pool guy does not have a clue how a SWCG works.. You can't "restart" it using chlorine of any kind.. Maybe he is thinking what I was thinking when I said your cell may not be bad... If you have algae, even if you can't see it, it will eat more chlorine than your cell can generate.. So he is adding "shock" to fix the algae problem (so he thinks) and that would allow the cell to generate enough chlorine for your pool.. (Of course this assumes the cell is good..)
Here is what I would do... Just before dark, I would add enough Liquid Chlorine to bring your FC up to 6 or 7 ppm.. I would then run an OCLT or Overnight Chlorine Loss Test.. to ensure nothing is in your water eating your chlorine. Assuming you pass the OCLT, I would tell the new pool guy to install the new cell..
Thanks for the additional info..
Thanks Jim,
Yes my SWG cell has been running at 100% since last week. CYA is 70.
On 2/6 my filter sprung a leak in the upper housing. I did a temporary fix. Cleaned all the grids and added DE and shocked the pool because the cell didn't seem to be working and I have needed to manually add chlorine to keep levels to target.
On 2/7 the brand new pool guy tested my pool for phosphates and insisted he put in a phosphate remover. I didn't think this was necessary, but he convinced my husband maybe he knows more than me.
On 2/9 my repair failed, so we limped along adding chlorine to keep the water sanitized until 2/13
On 2/13 I put the new lid on the filter.
On 2/14 Pump running 24/7, chlorine level was 0%. Increased percentage to 100%, and added liquid chlorine.
On 2/17- I am certain cell not working. Adding chlorine daily.
On 2/16- Decided I am going to add Borates for pH rise, since for the last 5 years this has been an issue. Also figured this may help with SWG if it works at all! I did not tell pool person about borates, he has never heard of them anyway.
On 2/18- Pool person adamant he does not want me to add any chlorine whatsoever. Claims it screws up the SWG COMPUTER!! He added an algaecide to the pool today. I do not know what kind or brand. I hope it wasn't one containing metals!
On 2/20- Chlorine in pool went to "0". I left it like he told me to. It was all I could do to not correct this. It went totally against everything I have learned on this site.
Today 2/26- Pool person added granular shock. Over added MA (he did not measure!) and brought my pH down to 6.4!!! So I added 10oz of Borax to help increase pH, TA is 70 so I wasn't too worried about bringing it up. 1 hour after the pool person added granular chlorine, my Cl was 10.5 at 12:45 this afternoon.
-As of 2:30pm my pH is up to 7.2. TA is still 70. My chlorine is 9. I will keep the infinity edge going all day to aerate and bring pH up to desired 7.7
NOTE: I HAVE ALWAYS HAD BEAUTIFUL CRYSTAL CLEAR WATER, MY CHLORINE LEVELS ARE NORMALLY MAINTAINED ADEQUATELY BY ME! I hope I didn't get off topic here. It doesn't seem likely that the SWG is working, does it. I will do the chlorine occult test and report back. Thank you for the advice!
