Thank you. I do not like hauling the jugs. That's good to know about the fc. I worry doing slam that its going to bring the iron back out. I asked in the equipment forum and someone posted the Circupool RJ series. Once my husband home from work I'm going to show him and make an order. greatly appreciatedA SWG certainly has its advantages. No more jug-dumping, but you do still have to test the FC and occasionally the salt level. While the SWG may appear effortless, you still need to ensure it's operating properly, hence the FC testing. But with SWGs, we recommend a higher CYA level (70-80) which for SWGs allows the FC range to be lower than with a non-salt pool. In that regard, the lower FC level may be beneficial to your iron situation.
