- Jul 21, 2013
- 65,386
- Plaster
- Pentair Intellichlor IC-60
I have a question, to remove the iron from the water using metal remover and something like fiber filter is it best to have low chlorine or high?
You want to have the iron in solution for it to be filtered. Chlorine level does not matter. You want lower pH as high pH causes iron to come out of solution and deposit on surfaces.
A sequestering agent may help keep iron in solution and precipate so it can be filtered.
Iron Fill Water Filter - Further Reading
