- May 23, 2015
- 25,718
- Plaster
- Pentair Intellichlor IC-60
I’ll keep it simple (I’m mobile at the moment and it’s hard to drive and explain chemistry at the same time).
AA is a reducing agent. It “reduces” iron 3+ ions (insoluble at near neutral pH) to iron 2+ ions (highly soluble at near neutral pH). Most stains on pool surfaces are iron (III) compounds (oxides and hydroxides). Iron 2+ ions are not stable in highly oxidative solutions (chlorine is an oxidizer) and so they will quickly convert back to iron 3+ ions. However, if you add a sequestering agent (there are many types of these) then the sequestering agent can hold the iron 3+ in solution by binding to it before it can react with oxygen to form scale. Over time chlorine destroys the sequestering agents causing the release of iron back into solution and, ultimately, causing stains. Some sequestering agents are simple phosphate based chemicals that are good at holding iron in solution while other sequestering agents are charged polymeric ions that will capture the iron and can precipitate out of solution as a solid inside the filter (though no guarantee that it will). All sequestering agents are susceptible to chlorine oxidation, some more quickly than others.
The only way to truly eliminate iron staining is to get rid of the source of iron in the fill water used in the pool. Well waters, especially ones from acidic or shallow aquifers, will generally be high in iron content.
