Forgot to mention our slide is on backorder. Which is fine because our pavers are on backorder too...
Oooooooh. I’m awesome at calling these too !! It will be *exactly* when they get there and not a moment sooner. I hope this helps.Orientation has been moved to when they get here
Do I need to wear gloves with the concentrated chemicals?You already added your own CYA so remove them and keep the FC where it needs to be with liquid dosing.
Sorry I don’t have one or know them well. Can you just set the dial to 0 and let them be ?Do I need to wear gloves with the concentrated chemicals?
yes. Let them dry out on a a plastic of some kind that you do not care about. Once dry, you can store them in a sealed container.Do I need to wear gloves with the concentrated chemicals?
Snoobug, I am following your posts closely because I'm about a half week behind you and have no idea what I am doing. My water was put in the pool yesterday but the electrical isn't getting done until today/tomorrow so no pump! I'm over here sweating about what will happen with my stagnant, non-treated waterOmg I'm scared to touch it... I don't know anything but what I've read in the manual over a month ago... I'm going to wait... I hope you are right. The water is circulating so it must be working...
Thank you for responding so quickly!
I know exactly what you're going through... hang in there!Snoobug, I am following your posts closely because I'm about a half week behind you and have no idea what I am doing. My water was put in the pool yesterday but the electrical isn't getting done until today/tomorrow so no pump! I'm over here sweating about what will happen with my stagnant, non-treated water
75? That's not considered cold here in the MidwestThe kids have been swimming for hours in the 75 degree water. It. Is. Cold.
yesHow do I open the cya mixing bottle. Do I cut the top?
I can not imagine how many times you have typed this. I know I've read it many times. Thank you so much for being patient with all us newbies!!!When you do the CYA test, try this next time.
Once you have your solution ready, back to the sun, etc. Fill the vial to a line, say 80, lower the vial to your waist level and glance for the dot, you see it, add solution to the 70 line, glance, see it, repeat until you no longer see it with a glance. Then use the CYA value one step above the line you read. So if you stopped at 50, use 60 ppm CYA.
The vial is in logarithmic scale. So it is not viable to interpolate between the lines. Just use the whole numbers, such as 50, 40, 30, ....
How much stabilizer have you added to the pool?
