I had the same conclusions so no finger pointing from me.I jumped to a lot of conclusions there.
What is the inside blue dial?View attachment 348207
Barometric pressure I believe.BAR...it's a metric unit of measurement for pressure
You are correct.Barometric pressure I believe.
Go into settings and make sure track filter pressure is turned on. And then to add an entry it is under perform maintenanceOk another dumb question... how do I add my filter pressure to pool math? I went to settings and added it as an extra tracking item.
That should be it. I would hold off for now. You may need a mini SLAM once the pool is handed over to you. At that point run it at full rpm for your baseline. Less PSI works too but it’s easier to tell 25% of the bigger # when the time comes.how do I add my filter pressure to pool math? I went to settings and added it as an extra tracking item.
Ohhhh very good! I believe it's been running since 9am.That should be it. I would hold off for now. You may need a mini SLAM once the pool is handed over to you. At that point run it at full rpm for your baseline. Less PSI works too but it’s easier to tell 25% of the bigger # when the time comes.
Omg I'm scared to touch it... I don't know anything but what I've read in the manual over a month ago... I'm going to wait... I hope you are right. The water is circulating so it must be working...If there are no bubbles it can appear empty when its full. Change speeds and try to,make a bubble happen
Oh, well jeeeze........ that makes all the difference!!!!! Yeah, you are 100% fine. The pump basket water can be so clear its fooled us all. And many times each.The water is circulating so it must be working
