intex pool and deck build
Vogi
2
I have a very similar build in mind/going on right now. This is my first attempt at this pool thing (24x52 agp intex), and I've gained some great ideas from all the posts here. I was wondering what type of ladder you have here and where you found it? Thanks for sharing your pics.
jsf0656
313
south georgia
amazon.com its a stainless steel ladder. very good quality. however i did order the steel flanges to replace the plastic ones. also on amazon. look under pool ladders for above ground pools. :goodjob:
jsf0656
313
south georgia
ForeverNewbie said:
I adore your pool! So inspiring!!
thanks very much for your comments. however there are many great intex posters on this forum that should be your primary focus. check out the above ground section on the forum especially the useful links for intex owners at the top of the page. find the post by crookm11 as he has some great ideas along with many others. there is a wealth of info out there. happy searching! :wave:
AleyFamily
1
I hope you don't mind me asking questions..
I love your setup btw.. We are looking at getting a 18x48 pool this summer and would like to install a deck as well. How big is your deck? and what are the concrete things that are holding the 4x4's up? I have never seen them before but that would save digging holes :)
We are thinking a 10x12 deck but yours looks like a great size.
Thank You!
jsf0656
313
south georgia
thanks for the comments! the deck is about 16ft wide and 10ft deep. we made it the width of the 16x48 pool. its great for the kids to jump off into the pool and just barely enough room for the 10ft slide. its also nice to have in that the kids keep their feet clean when entering the pool without touching the ground, and leaves enough room for table and chairs for the adults while leaving enough for the kids to play around. however i'm already thinking about next year as the grandkids are getting bigger and want a bigger pool. but for now its just right for them. but i will probably enlarge the deck to match the bigger pool. BTW the concrete blocks are called dek-blocks. they provide the foundation for the post without digging holes. they work great! you can get them at lowes or home depot. :wave:
msugg
1
how much room (deck) did you allow for the slide? I'm thinking of building a section of deck just for a slide but not sure how much room to allow for. Thanks.
jsf0656
313
south georgia
the deck was built with no plans. we just kinda freelanced it. as far as the room for the slide we measured the difference from the pool edge to the end of the slide including about a foot overhang over the pool. then we raised the slide up to the angle that we felt would be safe but also gave the kids a good fast slide into the pool. it came to about 8ft actual room for the slide but we had to figure in the space needed for some steps up to the top of the slide and the platform for the slide to mount to it. it took all the room to the back of the deck as you can see from the pics but it came out just right! :)
jsf0656
313
south georgia
finally got around to hard plumbing my intex sand filter to the pool. here are some pics...[attachment=2:27gavdhz]19607.jpg[/attachment:27gavdhz][attachment=1:27gavdhz]60721.jpg[/attachment:27gavdhz][attachment=0:27gavdhz]63701.jpg[/attachment:27gavdhz]
jsf0656
313
south georgia
also want to give a big thanks to mark(crookm11) for all of his insight and help on alot of the ideas that i have incorporated into my pool setup. hats off to you mark! :wave: :party: :whoot: :cheers:
jsf0656
313
south georgia
here is my new fountain! thanks again to mark(crookm11)for all his help :wave: i will eventually plumb it on the outside of the pool.
now, here is some pics :whoot: :party: :cheers:[attachment=2:1u0hhz1g]2024.jpg[/attachment:1u0hhz1g][attachment=1:1u0hhz1g]60693.jpg[/attachment:1u0hhz1g][attachment=0:1u0hhz1g]13186.jpg[/attachment:1u0hhz1g]
crek31
Platinum Supporter
877
Such a great set up! I am so worried about trying to cut my liner to add a skimmer and convert to "regular" fittings so I can connect a regular pump (so I can have enough power for a heater). Aside from wanting to ask what you'd charge to come modify my pool (really!), I've got to ask . . . Is your neighbor seen across the fence a fellow BBBer?
jsf0656
313
south georgia
ihad those same worries about cutting the liner as you are now. it really was not hard at all. having a skimmer makes all the difference. that why i decided to convert the old suction port to the fountain. i wish i would have went ahead and did the fountain when i did the hard plumb while the water was low but the thought never crossed my mind :roll: YES the neighbor is a fellow BBBer! he has had that pool for 4-5 years. he does fine with it! :cool:
jsf0656
313
south georgia
BTW put in that skimmer, YOU WILL NOT LOOK BACK! :whoot:
