Hi Everyone,
My current setup is 8 years old:
- Pentair Intellitouch (System i5+3) panel
- Heatwave Superquiet Heat Pump
- Pentair VS Pump (model 353114.E)
- Autopilot salt chlorine generator (Pool Pilot Digital Nano)
- Silencer Air Blower
- Levelor K110 Electronic Water Fill System
- Intermatic PX100 Low Voltage Pool / Spa Light Transformer
- Spa Side Remote (model iS4)
- Pentair Indoor Control Panel (model 510138)
Over time, the following systems have broken or no longer work properly:
- Pool LED light (I think it's a Globrite)
- Spa-side remote
- Intellitouch Indoor Control Panel (screen lights up, but nothing displays and all buttons no longer function)
- Levelor Auto Fill
- *Possibly* the thermostat that turns off the heat pump. I can turn the heat pump on, but it heats the pool without stopping at the set temperature.
I've been having the pool run using the built-in schedule on the Pentair VS Pump, but this functionality is very basic and requires frequent resetting. Basically, the automation and many of the features just don't work correctly anymore. I'd like to repair or replace the above systems, and add wifi / app functionality. If I'm going to spend the money, should I go back with similar equipment, or would you guys recommend something different altogether?
I'm not married to Pentair per se, and anticipate that the needed repairs would be expensive as it is.
Good longevity and wifi / app control are major goals, though!
- Spa-side remote
- Levelor Auto Fill
