The intellicenter is set to heating mode, at 85 degrees. Woke up this morning and the water was 87 and the heat pump was still on. Heater never turned off. Same thing happened in the spa. We set it to 96, and it rose to 100!
Here's the setup:
Thermeau electric heat pump has a 2-wire remote connector that is connected the the gas heater relay on the Intellicenter. Intelliecenter heater is set to gas (even though the heater is an electric heat pump).
Here' what works:
I can manually turn on the heat from the panel, and it will turn on the heater. Likewise, I can turn off the heater from the panel, and it will turn off the Thermeau.
If I turn on the pool, it will automatically turn on the heater.
Things I've tried:
I heard that a missing solar temp sensor can throw off the Intellicenter. I added one, and the Intellicenter now acknowledges a solar temp. Previously, it said "error."
Entered service mode and manually operated the "heater" button. The button does turn the heater on and off as expected.
Played around with many settings (anything heater related, like heat delay mode, etc.).
Can anyone point me in the right direction?
Here's the setup:
Here' what works:
Things I've tried:
