Hi all
I got a notification yesterday on my panel stating a firmware update was available - everything at this point was running great - I went ahead and did the firmware update to 2.006 (wish I hadn't) - after it downloaded and installed / rebooted... my pump will no longer respond to on off commands from the panel - it will however respond to the Circuit commands and features I have programmed - it also runs the schedule with no problem
if I turn on the pool - the pump does not start or respond - the intellicenter believes it is running - then I turn on the Cleaner Circuit - the pump kicks on and runs the cleaner - keep in mind this is during the scheduled filtering "pool on mode" highest pump speed will take priority - then it is running the cleaner - turn off the cleaner - the pump slows down to "pool mode" and continues to run
I can not turn the Pool or spa on or off manually without putting it in Service Mode unless I use a circuit or feature
I tried to export my setup to USB and that failed (wanted to do a system default to factory settings) - but I dont want to reload all my programs - my panel is the IPS5
anyone have any problems? my pump is an intelliflow VSF pump (only 1 pump for both Pool and Spa)
Any Idea How I can export my configuration ? not sure why the USB fails, I formatted a fresh USB, put it in, went to export, then named the file, it sees the usb and then quickly says failed - what am I doing wrong ?
any help is greatly appreciated
