Ahultin
- Aug 19, 2021
- 1,597
- Plaster
- Pentair Intellichlor IC-40
Yes - a couple times. I was forced to reboot the panel as when I went to spa mode the first time post upgrade the panel froze. Then when it came back the spa was gone. Rebooted again to get it back and had to re-add all the spa settings (pump speed/heater/etc)Have you rebooted your local panel? I had weird stuff happening with timing of things because apparently the clock was wonky and I didn't realize it. Just make sure to eliminate that. Double check the clock settings.
--Jeff
