@DB-Cooper
Thanks for the update.
I tried using the "Over-the-Air" (OTA) update method and it did work.
Looking through the Release Notes, it appears that they were testing that capability that was supposed to work 3 years ago. Maybe they got that feature together now.
Switched over to
intellicenter2.com with no problems.
Again, looking through the release notes, it appears that the hosting has now migrated to AWS which as you mention "should" be more solid.
Below are the release notes for what its worth.
Release Notes
version 1.064
- Send WriteParamList with _5451,MODULE and Panel objects to AWS Backend upon successful LOGIN.
- Fix to not to send response for NOTIFYLIST_404 in icweb.
version 1.063
- Handle NotifyList 404 in icweb to clear Notifications.
- Handle Empty Message from AWS Backend.
- Removal of sending WriteParamList after LOGIN in to AWS.
- Fixed Super Chlorination Timer (Jira #IAM-438 and #438).
- Fixed Service Timeout Mode Timer (Jira #IAM-437).
- Fixed Logging Timer.
- Fix for More reliable Login to AWS Backend(#435).
version 1.062
- Replaced TEXT PING/PONG with RFC PING/PING in icweb for AWS Backend.
version 1.061
- Fixed GetRegisteredProperties AUTH Failure issue in icweb (Jira #IAM-406).
- Fix for email account persistence in web login screen after reboot.
- Fix to remove the firmware package when the user selects NO in the New Firmware Available Screen after AUTO download.
version 1.060
- Changed OTA LOWNLOAD Server for AWS PROD And BETA [UAT] users in ic.
- Fix for Incorrect ACT when the Schedule Turns ON/OFF for WebClients in icweb.
- Fix for temperature Sensors PROBE and SOURCE related to calibration in icweb.
- Added Waits for base64 encoding and openssl password encryption process for more reliable encryption in icweb.
version 1.058
- Fix to not to Reboot OCP after User Login.
- Fix for temperature Sensors.
- Fix to send Authentication immediately as soon as the user tries to login.
- ICWEB logging can be exported to USB via Export Debug Data.
version 1.056
- AWS MIGRATION.
Made PROD and MAIN Environments same.
version 1.054
- AWS MIGRATION.
Updated URI’s for ALL Environments. These URL’s will remain unchanged henceforth.
version 1.049
- No Changes. OTA Testing version
version 1.048
Thanks again..
r.
