mzuniga
- Feb 12, 2021
- 69
- Plaster
- Pentair Intellichlor IC-40
I can’t get my Apple Watch to work. I logged in on the iPhone app (remote), the screen on my watch that says connect only displays for a 1/2 second, then says please login to IntelliCenter phone app, which I am.I kind of posted similarly above. I did get it to work by going back in the watch and pressing the connect button.
Thanks for the update!
Scratch that. 15th time it worked.I can’t get my Apple Watch to work. I logged in on the iPhone app (remote), the screen on my watch that says connect only displays for a 1/2 second, then says please login to IntelliCenter phone app, which I am.
Rebooted my phone and watch, still no luck. Frustrating.
Good point, although I think the issue is Pentair is a pool equipment company, not a tech company! I got mine to work after the 1,000th time (ok, maybe it was only 15).You guys trying to get your watch to work should tell each other…
There may be a pattern to what works and doesn’t.
- What version AppleWatch
- Watch OS version
- IOS version
I‘m disappointed that this release was only bug fixes/changes to support the move to AWS. I feel like there is a lot of opportunity to add/refine features. They are still on version 1!@DB-Cooper
Thanks for the update.
I tried using the "Over-the-Air" (OTA) update method and it did work.
Looking through the Release Notes, it appears that they were testing that capability that was supposed to work 3 years ago. Maybe they got that feature together now.
Switched over to intellicenter2.com with no problems.
Again, looking through the release notes, it appears that the hosting has now migrated to AWS which as you mention "should" be more solid.
Below are the release notes for what its worth.
Release Notes
version 1.064
- Send WriteParamList with _5451,MODULE and Panel objects to AWS Backend upon successful LOGIN.
- Fix to not to send response for NOTIFYLIST_404 in icweb.
version 1.063
- Handle NotifyList 404 in icweb to clear Notifications.
- Handle Empty Message from AWS Backend.
- Removal of sending WriteParamList after LOGIN in to AWS.
- Fixed Super Chlorination Timer (Jira #IAM-438 and #438).
- Fixed Service Timeout Mode Timer (Jira #IAM-437).
- Fixed Logging Timer.
- Fix for More reliable Login to AWS Backend(#435).
version 1.062
- Replaced TEXT PING/PONG with RFC PING/PING in icweb for AWS Backend.
version 1.061
- Fixed GetRegisteredProperties AUTH Failure issue in icweb (Jira #IAM-406).
- Fix for email account persistence in web login screen after reboot.
- Fix to remove the firmware package when the user selects NO in the New Firmware Available Screen after AUTO download.
version 1.060
- Changed OTA LOWNLOAD Server for AWS PROD And BETA [UAT] users in ic.
- Fix for Incorrect ACT when the Schedule Turns ON/OFF for WebClients in icweb.
- Fix for temperature Sensors PROBE and SOURCE related to calibration in icweb.
- Added Waits for base64 encoding and openssl password encryption process for more reliable encryption in icweb.
version 1.058
- Fix to not to Reboot OCP after User Login.
- Fix for temperature Sensors.
- Fix to send Authentication immediately as soon as the user tries to login.
- ICWEB logging can be exported to USB via Export Debug Data.
version 1.056
- AWS MIGRATION.
Made PROD and MAIN Environments same.
version 1.054
- AWS MIGRATION.
Updated URI’s for ALL Environments. These URL’s will remain unchanged henceforth.
version 1.049
- No Changes. OTA Testing version
version 1.048
Thanks again..
r.
If you're referring to nodejs-poolController, absolutely. No problems there.Can somebody confirm poolController is working with the new firmware?
JimI‘m disappointed that this release was only bug fixes/changes to support the move to AWS. I feel like there is a lot of opportunity to add/refine features. They are still on version 1!
You seem more plugged in to Pentair than most. Do you know if they are working on a more substantial release? And if so, when that might be released?
Thanks.
Couldn't get the new app to download until I upgraded to latest iOS version (15.1).You guys trying to get your watch to work should tell each other…
- Watch OS version
- IOS version
I've mentioned some of these, but there are some thoughtful improvements:clicked the update firmware button (my intellicenter is hardwired via Cat-6 to my router) rather than USB - it took several hours to download the update (must be a 4k server connection) - eventually asked if I wanted to upgrade - it rebooted and loaded new SW just fine - switched over to IC2 iphone app with no issues - don't see any functional changes/improvements
