The downside to the Intellibrite LED Lights for both the color changing and white light version is that the bulb is not replaceable. The Intellibrite uses and integrated LED PCB Board meaning that when the light goes bad then the entire fixture needs to be replaced.
One last thing to consider is if you have multiple lights (i.e. pool and spa, or 2 lights in pool) and you go color changing then you will want to go with all being the same brand so that the light synchronize with each other.
