Hi,
I replaced my dead Pentair Max E Pro pool pump with a 3 HP Black and Decker VS pump. I have an a Intellitouch i7 +3 automation system that connects to an App using screen logic.. I replaced the B&D control panel with the automation adapter that can be used for the B&D pump. When I went to connect the automation cable from the pump to the board, I found a rats nest of cables and could make sense of how to make the connections. I viewed several Youtube videos with folks connecting VSPs to automation boards but never with the i7+3.
I used the same electric connections from the old pump on the new B&D.
When I try to fire up the pump (turn the breakers on), it is not getting power. The App will not fire up the pump either. The breakers (in the automation box and the main house panel) are not tripping. My uneducated guess is that the pump is not getting power due to the panel not being connected to the pump. Does this seem like a plausible explanation?
Can anyone give me some ideas on trobleshooting this issue or is anyone an expert on Intellitouch systems? I took lots of picture of the the low volage side and high voltage side if that helps.
