5ppm worth of liquid each day until your kit comes
PoolMath will help you calculate the amount (you will need to estimate how many gallons of water you currently have in the pool)
Pour it in slowly, away from the liner (usually in front of a running return) but you can use the stream of the running hose since I don’t think you’re up & running yet.
Brush the area well so none rests on the liner (as it’s heavier than water).
You will need some cya (stabilizer) as well (30 ppm worth (about 5 lbs.once the pool is filled to start- then at least 5 more pounds later- after circulating & testing after the first addition to eventually reach around 70ppm) so get some of that purchased. It’s usually in 4# bags.
we recommend putting the amount poolmath calls for an a sock
![Socks :socks: 🧦](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f9e6.png)
/splitting it between multiple socks & hanging it infront of a return until it is squishy then you can squeeze it until it all dissolves. You don’t want the granules or the sock to get on the liner.
You will also need some muriatic acid on hand to lower ph if necessary (usually sold in 2 gallon packages)
You will need to purchase enough salt to operate your swg. About 3000 ppm worth. Poolmath says about 480# or 12 40lb bags. You won’t be dumping it all in at once. Add 3/4 of the amount then let it circulate 24hrs and test before adding enough to reach your goal. Then let it circulate again for 24 hours & retest. The swg should be off during this time.
They sell all of these at lowes & Home Depot in the pool area. The only thing to avoid is clorox pool salt. The others should be ok .
To recap:
* 5ppm worth of liquid chlorine daily until you can test so you don’t get swampy
Shopping List;
*Liquid chlorine - several gallons as you’ll be using it daily until your swg is up & running
*Cya- 10-12 lbs.
*Muriatic Acid - a couple gallons to have on hand
Salt - 480# —— twelve 40# bags
*A brush & a skim net with a pole if you don’t already have one
