In SLAM process
Tracey R
189
Boerne TX
As of 10:15am
FC 16.5
CC 0
PH 7.8
TA 280
CYA 35
I may be able to do 2 more FC tests today but I will be sparing until I receive the other powder.
daleyfolk
54
Boise,Idaho
About the cloudiness—something I would try is turning off the pump. Maybe the debris will settle on the bottom and then you can vacuum to waste. This worked for me when I had problems my first year of struggling with my pool. My sand filter just wasn’t doing a good job. It kept letting particles though and back out into the pool.
Tracey R
189
Boerne TX
Is there something like floc we at TFP use? With this SLAM process taking so long and being SOOOO involved for me, I'd hate to turn off the pool and get issues kicked up again.
gonfishin
334
Rochester, MN
If I were doing it, I’d do it on a day when I could add in the morning and check the pump hourly or so in the event pressure rises more than 25% after adding the DE. Maybe someone who has done this will chime in or you could start a new thread to attract the attention of an expert.
Reactions: Tracey R
Tracey R
189
Boerne TX
Thank you!! I will start a new thread and see what a monster this would be before starting it. I appreciate the advice
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
32,864
Folks need to see your "whole story" when offering advice. If you start new thread(s), folks will seldom take the time to search back and try to find out what you are talking about........they will simply skip over your new thread and go to someone else's that is easier to follow.
Reactions: Tracey R
Tracey R
189
Boerne TX
I back washed it this morning. First time since switching out the sand on Sunday. The pressure gauge didn’t tell me I needed to but from the return and circulation in the pool, I need it to do it. Anyhow, the backwash spit out some sand (I assume) although I really couldn’t see it. The water was tan/sandy colored then turned to clear after a bit. Rinsed afterwards until the water turned clear.
Reactions: Flying Tivo
Fast7
180
Plainfield, IL
Tracey, I noticed your logs are posting with time +5 hours into the future. Looks like you have wrong time set on whatever device you use for PoolMath app. You might want to fix that as it might be very misleading for someone trying to analyze your logs.
Tracey R
189
Boerne TX
IDK how that could be. I use my phone.
I noticed that recently also but have no idea how to fix it. Any suggestions?
Fast7
180
Plainfield, IL
I'm not sure how app could do it by default but when you about to add log, in a top portion of that window there is date and time you can adjust.
It gets auto populated for me correctly, and I can adjusted manually but have no idea why it would do that for you automatically.
As a workaround, you can always go back to the log that was added and adjust time manually.
