Convincing my wife to go out with a big bottle of bleach and a measuring cup every time she wants to use the tub is a tall order. The more complex it is to use the tub, the less likely it is to get used!
For Dichlor, I got a set of Tupperware Smidgets and once a week or so I can fill them all with a set dosage of Dichlor. Then, all one has to do when using the tub is grab a Smidget on the way out the door, then when done toss the contents in with the pump on, go inside to dry off, then go back out once dried off and dressed to close the lid.
Has anyone found any good methods to make Bleach more convenient, if we wanted to switch to using it? I was thinking, like, some kind of plastic bleach container that has a measuring chamber or something and allows you to just squirt the liquid directly into the tub? Or any other good ideas on a system that's easy to use/explain and/or lowers chances of spilling bleach?
