Algae on my pebble tech pool walls that I can’t get rid of. Salt water generator. My pool is now in balance and I am adding liquid chlorine like I think I am supposed to. It seems better but doesn’t all go away. Suggestions?
You need to follow the SLAM Process. To do that, you need a proper test kit. What test kit are you using? Can post a full set of water chemistry test results?
I suggest you read ABCs of Pool Water Chemistry.
