Idk what to do next...
Lots of folks helping you with solid advice. After you exchange water and follow TFP guidance, you'll see how easy this really is. Just exchange as much water as you can and perhaps leave about 18" or so in the bottom to keep everything pulled tight. Monitor the liner and walls as you lower the water. Once it's full again, things will be much easier. Hang in there!
Reactions: Geminisq
Thanks for the encouragement! Last 3 days have been over whelming, but I feel better now that the problem has been identified and I have a plan!
Can I just use a shop vac to vacuum up any debris on the bottom? And do I need to use anything in particular to clean the walls, ladder or plumbing?
You can. You can use just about anything that isn't too abrasive on the liner. Fairly common to use a water-bleach mixture, brush the walls, then rinse.
Ok. So it would be logical to scrub everything, rinse and then vacuum last?
Absolutely. As I said earlier though, just be careful about an empty pool. Watch the walls and liner closely so they don't move.
Reactions: Geminisq
I know that part makes me a little nervous. I'm going to try to bring it down to about 12-18 inches. It's draining now and is about 1" below the return jet. Thanks so much for taking the time to answer my questions!
Good morning all. I was in the hospital for 4 days and all my test logs in pool math are gone. I tried logging out and back in and still no logs. It's not a huge deal as I will be starting over once we refill, I just don't want to loose any going forward. Happy Memorial Day!
Mod Edit: Tagging Lee for attention @Leebo
We have drained 85% of water, scrubbed walls etc. We tried for 2 hours to get suction through the pump to vacuum the remaining algae and were unable to get it going, Idk why. At this point we are going to refill, start SLAM and then vacuum. There does not seem to be much solids (pic attached) left so I hope that will be ok. All suggestions welcome!
Reactions: Snoobug
There is really not much point in cleaning live algae. It will likely grow faster than you can clean it. Start the SLAM process and then clean the walls/bottom. You will need to fill enough water to get your pump running to do a proper SLAM. What are your current numbers?
No, but I wondered if that was why you could not find your data.
I have had a little difficulty/confusion navigating between Pool Math & Pool School.
Update: Added 4 gal LC 10% 5/31
Test results from today 6/1:
FC-80
CC-0
TC-80
PH-8.5
TA->300
CYA-100
First time testing with new kit, still familiarizing myself with test procedures. I did not want to try to run my 1st tests after midnight last night due to lack of light and exhaustion so I waited until this morning. Ran these tests twice to be sure of accurate results and correct test procedures. I will be watching the test videos today to further familiarize myself. Water is looking better.
I suspect you have an FC math error, we'll come back to that. First priority has to be lowering the CYA. That requires a partial water exchange. If you exchange half the water, it will reduce the CYA in half. You show the CYA at 100 but it might be higher, so when you change water don't be surprised if it's slightly higher. But you want the CYA down to about 50 or so. Do that exchange first before adding anymore chemicals.
For the FC test, do it as follows: 10 ml water sample size with ONE generous scoop of power (should turnip Barbie pink). Add drops, stir, and count until clear then divide than number in half. Example: 20 drops equals an FC of 10. Hope that helps.
CYA Testing:
Proper lighting is critical for the CYA test, so you want to test for CYA outside on a bright sunny day. Use the mixing bottle to gently mix the required amounts of pool water and R-0013 reagent, let sit for 30 seconds, then gently mix again. Recommend standing outside with your back to the sun and the view tube in the shade of your body at waist level. Then, begin squirting the mixed solution into the skinny tube. Watch the black dot until it completely disappears. Once it disappears, record the CYA reading. To help the eyes and prevent staring at the dot, some people find it better to pour & view in stages. Pour some solution into the viewing tube, look away, then look back again for the dot. Repeat as necessary until you feel the dot is gone. After the first CYA test, you can pour the mixed solution from the skinny view tube back to the mixing bottle, gently shake, and do the same test a second, third, or fourth time to instill consistency in your technique, become more comfortable with the testing, and validate your own CYA reading. Finally, if you still doubt your own reading, have a friend do the test with you and compare results.
Why so much chlorine? You slam target is 39ppm. 4 gallons of 10% will give you 47ppm of FC. If you drained 50%, refilled and still have 100ppm of CYA you need to do another drain/refill cycle before you slam the pool.
The instructions & math you just gave me are completely different than the instructions that came with my test kit. They instruct me to use 1 heaping scoop or 2 level scoops of the powder and to multiply the # of drops I added x .5 and record as free chlorine. I'm not great at math to start with but now I'm totally confused.
Where is you water level? Have you filled back to the middle of the skimmer? If so, your CYA is still on the high side. If it is economical for you to do another half drain, it will be much easier to manage the SLAM.
