Its the same instructions worded a little differently. Multiplying by .5 is the same as dividing by 2. Just use one scoop of powder and don't level it off. This is a heaping scoop.
Taylor suggests two scoops when using the 25 ml sample and multiplying by .2. That is usually not required. The ONE generous (or heaping) scoop is for the .5 (or half) count method. The one I noted above works just fine.The instructions & math you just gave me are completely different than the instructions that came with my test kit. They instruct me to use 1 heaping scoop or 2 level scoops of the powder and to multiply the # of drops I added x .5 and record as free chlorine. I'm not great at math to start with but now I'm totally confused.
Ok got the scoop info, thank you. As for the math it doesn't matter whether I use the 10ml or 25ml sample math because it's in order to obtain the same result?Taylor suggests two scoops when using the 25 ml sample and multiplying by .2. That is usually not required. The ONE generous (or heaping) scoop is for the .5 (or half) count method. The one I noted above works just fine.
Why so much chlorine? You slam target is 39ppm. 4 gallons of 10% will give you 47ppm of FC. If you drained 50%, refilled and still have 100ppm of CYA you need to do another drain/refill cycle before you slam the pool.
Got it.The 25 ml sample test gives accuracy to 0.2 ppm but it uses a LOT more reagent. The 10mm sample gives accuracy to 0.5 ppm and uses much less reagent. There is hardly ever any reason to do the 25ml test unless you were trying to "fine tune" a Chlorine Generator or something.
I actually drained more like 85-90%. Pool was draining when I had to go to the hospital on Thursday, I had my neighbor pull the hoses out of the pool because no one was there to keep an eye on it. It retrospect, I should have drained more out when I got home on Sunday. I just rechecked the DPD test, it's still at 80. I'm glad I bought the XL kit anticipating a lot of testing. So while it's draining again I need to figure out how I'm going to vacuum it. Idk why I can get enough suction on a garden hose to drain, but can't get suction started with my pump in order to vacuum it. Any suggestions are highly appreciated.Who knows![]()
Be sure not to drain all the way. You need to keep a couple feet in the bottom or your liner will shrink and rip when you try to re-fill.I actually drained more like 85-90%
I'm only going to drain 50% as I drained probably 85% last week. I don't need any liner problems, it's only a year old. We will definitely try that with the pump. Current CYA is down to 80 but Idk if that is considered accurate while I am draining. Thank you!Pool pumps are better at pushing water. (water between pump and outlet) Not so great at lifting water (from water level to pump).
They don't want to move air so much.
You might try lifting your vacuum hose higher than your pump and filling it with water. Then cap the end with your hand, submerge it under water and turn on the pump.
The idea is to get all of the air out of the inlet system before you turn on the pump.
I am reading it again. We found 4 packs of 1 gallon sodium hypochlorite 10% for a pretty decent price. Should I be using a lower strength with the vinyl liner? Thanks!If you are at 80 CYA currently, drain 50% of the water, then refill with tap water (has 0 CYA) then you will end up with a CYA of around 40 which is perfect.
After you refill I would begin the SLAM. I see you have your test kit, have you read up on the SLAM and did you locate a good supply of liquid chlorine?
SLAM - Shock Level and Maintain
We’ve all had to deal with a green pool. Clear algae from your pool with a SLAM! Read here to use shock level and maintain to clear your pool.www.troublefreepool.com
No the pump is not running, I'm draining.Wait, the water is not circulating. Make sure the pump is running when you pour your LC into the pool.
Then take a sample from anywhere, 18” below the water.
You drained 85% last week then refilled and drained 50% today?No the pump is not running, I'm draining.
MUCH better!Refilled now and CYA is 50. I hope this is workable.
