- Jun 8, 2019
- 4,576
- Vinyl
- Pentair Intellichlor IC-60
I did some maths for 26k gallons HereNew to 2023 - Wife Doesn't Immediately Shoot Down Salt Cell.
Perfect. Thank you, I'll share with her tonight.OK Dustin, we go back, so here's your specific maths to go over with the CFO.
1 gallon of 10% is 5 FC for 20k gallons.
$4 gallon = $0.80 per FC
$5 gallon = $1 per FC
$6 gallon = $1.20 per FC
$7 gallon = $1.40 per FC.
*best I can do at the moment is high $5s at Walmart, but you've done well in the past, here's hoping that continues.
IC40 has 3502 lifetime FC in 20k gallons, currently $1600, for $0.46 per FC.
RJ-45 has 5004 lifetime FC (probably overstated by circupool), currently $1380 for $0.28 per FC. Even if it *only* puts out the 1.4 lbs a day like the IC40, it's $0.40 per FC.
Replacement models don't need the ($500?) controller and save 30% more going forward.
Tell your wife you are saving even more money by not having to add tap water.Hm - had a lot of rain and snow in the spring. I think the pool is a little full.
This is sorcery do you have a specific method? I bought a large rolling trash can to put my covers (leaf & solid) in but at this point it looks like the leaf one will barely fit in there. I still don’t understand how in the world they got them in the boxes originally.Pool cover fully folded and put away.
I folded mine to a 4X20 strip and rolled it. Then I used 3 ropes front/middle/back to hang it from the garage rafters. (Tight to the beams though for head clearance).do you have a specific method?
When I threw the last one away it wouldn’t even fit all the way into the big green garbage can! Of course I was just wadding it up. They usually take up a huge portion of my she shed.I folded mine to a 4X20 strip and rolled it. Then I used 3 ropes front/middle/back to hang it from the garage rafters. (Tight to the beams though for head clearance).
