- Feb 6, 2015
- 7,808
- Plaster
- CircuPool RJ-45 Plus
It could be worse - there could be a negative sign in front of those lows.
I feel your pain. I got in my 71 degree water today… and it will probably be a month before the chance comes again.
Sorry, missed that wall mount. If you went with something similar to that but just a bit larger like 6U, you could then get your switch close to the patch panels and run short 6" patch cables. Something like this:The patch panel is on a 6" deep wall mount bracket. And I already have the 48 port switch, but it just sits on the shelf below the patch panel. The cords there are.......less neat. Not sure how to handle those. >.>
Pretty sure it is ... I believe there are 4 little holes on each side by the front. That's where the "ears" attach to the switch. This allows you to secure it to a rack.I'll have to see if the 48-port switch we got is rack mountable![]()
