- Feb 6, 2015
- 6,278
- Plaster
- CircuPool RJ-45 Plus
Very fast too. Ratcheting pipe cutters make a huge difference.Nice clean install - well done!
I would skip this part and see if the world keeps spinning. I bet you won't see a difference. There's no way around activating the heater for 6 hours if that's what you need, but if your water is already moving all day, the full RPM for 2 hours isn't doing much that the 6 hours at 2k wasn't already doing.like 2 hours at full speed (3000 RPM) to mix water better and skim better,
Just the Diamond Crystal stuff. The Morton stuff is still 40 lb bags.Until you mentioned it I didn’t realize that you get 10 more # with solar salt than pool salt
We’re really getting the shaft around here!
Diamond crystal wins again!Just the Diamond Crystal stuff. The Morton stuff is still 40 lb bags.
This is weird. My Lowe's only has the 40# bags of that. I wish they came in 50#'rs!Just the Diamond Crystal stuff. The Morton stuff is still 40 lb bags.
--Jeff
--Jeff
GRRRRRR.... I wish we had a Menard's here.
--Jeff
My friend drove all the way to a menards up in Missouri from here to get his siding- he said even with the gas it came out cheaper than lowes or hd.Agreed!
I have a friend (in another state) that has a Mernards. She has access to much cheaper chlorine (and much fresher!) and salt than we ever have here.
When installing SWG with VSP /w internal timers, you can use current sensing relays to measure if the pump is running and only power the SWG while it is on. It's less useful if pump is scheduled for 24/7 runtime, but gives better protection than just relying on the flow switch. Search "SWG current" and you will find threads like: Current Sensing Relay for SWG with Variable Speed pumpI assume you don't run the pump 24/7.
How are you going to control power to the SWG without a timer or automation?
The flow switch is the secondary safety device. Automation or timer is the primary safety device.
I will absolutely check this out. I don’t need my pump going down and the flow switch failing.When installing SWG with VSP /w internal timers, you can use current sensing relays to measure if the pump is running and only power the SWG while it is on. It's less useful if pump is scheduled for 24/7 runtime, but gives better protection than just relying on the flow switch. Search "SWG current" and you will find threads like: Current Sensing Relay for SWG with Variable Speed pump
.... and I love that 3-way install. Looks great!
