- Jun 8, 2019
- 4,576
- Vinyl
- Pentair Intellichlor IC-60
OK, so:
- Get a new box to contain the CSR
- L1 line (one of the two from the breakers) goes to my exterior toggle switch. I then splice it over to the SWG's L1 input on one line. Run through conduit up to the box with the CSR, splice it there, have one line looping around the sensor, then send it down to my pump and the other to the 1 pin on the CSR.
- L2 line (second of the two from the breakers) gets spliced and goes to the pump on one line. Other line gets spliced and put to both 2 and 3 on the CSR. Then a wire from 4 goes to the L2 input on the SWG.
- Neutrals will all just go direct to my box with the toggle switch and get wired together, pump neutral line to SWG neutral line to the neutral coming from the breakers. Edit: never mind, 240v apparently doesn't need a neutral (see prior disclaimer about how electricity is my blind spot)
- Grounds similarly all just tied together.
Do I have it right?
EDIT: Maybe a box like this to contain the CSR?
Do I have it right?
