- Jun 8, 2019
- 4,581
- Vinyl
- Pentair Intellichlor IC-60
Thinking more about this: Is this what you mean?I was wondering about the heater use in WI. If you didn't use it much, a heater bypass would be beneficial to have as you could run the pump as a lower RPM and still satisfy the SWG flow switch. But since the heater is a big part of your pool enjoyment, a heater bypass would be good in case the heater broke as you could isolate the heater and still run the pump. You may still consider the heater bypass, it will add about $150 in parts for the 3-way Jandy valve and Jandy check valve.
The Pentair SWG is more easily controlled with Pentair automation.
Just need a 3-way valve to divert water either to the heater or to a pipe that bypasses it. Then need a 3-way PVC fitting (no valve) to connect that pipe to the pipe beyond the heater, and a check valve to make sure the water is directed to the return and doesn't go back into the heater. Correct?
