Hello everyone. I have a pool I had built close to 5 years ago and a IC40 was put in. I havent had any trouble out of it until this year when I went to open my pool it shows a red flow light and the salt level is blinking between good and low.
My assumption is the salt level reading isn't working because it doesn't detect flow. I decided to order a replacement flow switch (off brand from Amazon) and even after replacing it I have the same problem.
It is facing the correct way, the flow is perfectly fine, the cells are clean and I cleaned then again (3/4 water with the rest muratic acid). When I hold down the more button for diagnostics it shows green on the cell and 60% life (three green dots).
Do you think this device is bad or I happen to get a bad flow switch? The strange thing is with the original flow switch it would sometimes show green flow but very rarely since opening a couple weeks ago. If it did turn green it would turn back red a few minutes later.
I'm at a loss and hoping I do not need to replace it this year. Is there any other diagnostics I could do?
