Now that the Intellichlor is functioning I'll spend some time dialing it in.
What I have noticed is that if the pool runs too low say 900rpm the intellichlor reports a low chlorine level 2300ppm but if I increase to say 2000rpm or higher the intellichlor reports closer to 4000ppm. Is this behavior normal? After reading that recommended flow is 25GPM I'm going to change my schedule to set minimium gpm to 27 and adjust run times. I was thinking of starting at 4 hours @ 27rpm as my lowest speed schedule and test FC daily to see how it works out. More of a ballet than expected LOL... Live and leard.
Is it true that if the intellichlor is setup through the easytouch that changes must be made on the easytouch panel and not the intellichlor unit? Or can you adjust on either?
