*** I think it's algae. First time issue in 10yrs
mp333
2
North Haven, CT
Hello,
I am new to this forum. I am having my pool patio pavers replaced. It's a round gunite (25k Gal) pool and lots of cuts in the paver to fit the shape. So there has been some paver dust in the pool. The install is taking longer than expected. Any ways did have some dirt and sand like material at the bottom of the pool and it freely moved around. Figure I would clean it once they were done with the patio. Anyway the pool was running on schedule every day and for last two weeks it has dumping water into the hot tub and not the main pool. So much of the circulation other than the pump pulling water from the main drain in the pool. I am thinking this is my cause of the problem... Also it has been raining very hard here in northeast.
I added three gallons of shock and it seemed to loosen up a bit and then I had the water tested after and here are the results. Last pic is before I added phosphate remover and muratic acid.
Any help is appreciated.
Thank you
thumbnail_IMG_9420.jpgthumbnail_IMG_9418.jpgthumbnail_IMG_9417.jpgthumbnail_IMG_9416.jpg
Welcome to TFP.
Do an Overnight Chlorine Loss Test This can confirm it is algae. it looks like aglae but since you have lots of other debris, lets do this overnight test.
Prepare to do a SLAM Process. This is NOT a just add shock treatment. This is a dedicated process to completely kill algae for the long term. How do you chlorinate your pool? You will need liquid chlorine to perform the SLAM. Also you will need a proper test kit. Test Kits Compared
You will need to test every 3-4 hrs during daylight so important to do your own testing. Order a test kit now so you can prepare for SLAM.
Welcome to TFP.
This is the way. The pool store test can’t be trusted, but even if it could I’d imagine 3 gallons of shock would take you way above 10ppm FC so something organic is likely eating it up.
You need a good test kit with FAS-DPD that HermanTX linked. Add 5ppm Chlorine daily until it arrives then perform the OCLT and likely SLAM.
