Hello,
I am new to this forum. I am having my pool patio pavers replaced. It's a round gunite (25k Gal) pool and lots of cuts in the paver to fit the shape. So there has been some paver dust in the pool. The install is taking longer than expected. Any ways did have some dirt and sand like material at the bottom of the pool and it freely moved around. Figure I would clean it once they were done with the patio. Anyway the pool was running on schedule every day and for last two weeks it has dumping water into the hot tub and not the main pool. So much of the circulation other than the pump pulling water from the main drain in the pool. I am thinking this is my cause of the problem... Also it has been raining very hard here in northeast.
I added three gallons of shock and it seemed to loosen up a bit and then I had the water tested after and here are the results. Last pic is before I added phosphate remover and muratic acid.
Any help is appreciated.
Thank you
Thank you
