- Dec 14, 2019
- 74
- Vinyl
- CircuPool RJ-45 Plus
I recently installed an RJ45+ it was running initially and I could see the haze like it was generating chlorine. However it was showing my instant Salt reading was only around 2600 and my average is still showing at 2500. The water was cold and around 57 so I thought it could have been something with the water temp because I began to get Low Temp on the screen and the generating light now just flickers.
We are now having warmer weather and my pool was at 66.5 (manual thermometer +/- 2) today. I had the SWCG turned off due to the lower temps and now with the high temps I thought I would test it again. Unfortunately, after turning it is initially says it is generating at the 50% setting and then I get Low Temp on the screen and the light beside generating just flickers again. I also have not got the hazy water coming from the cell.
I have read about possibly needing to calibrate and I have search high and low on how to do so with no luck. I attempted to contact both CIrcupool and DiscountSaltpool.com but both were closed by the time I got home for work and don't open until Monday. This is going to bug me all weekend at the temps are now in the 80s.
Any help or suggestions would be great. I am trying to figure out a way to reset the console. The power already disconnects with my timer so not sure how else to reset it. Sorry I am rambling just frustrated.
