- May 23, 2015
- 25,693
- Plaster
- Pentair Intellichlor IC-60
Could be wrong, but I think he glued in a new spyder gasket... @blackhighlighter can you confirm?Silicone does not need to “cure”, it’s a lubricant and non-hardening sealant for the o-ring, not glue. You can put the pool right back into service after applying it and getting everything sealed back up.
Hi there- I shared some pictures above.Blackhighlighter, could you put your type of pool equipment in your signature? What type of filter do you have?
SLAM Process@PoolStored - Test kit has arrived.
My plan today is the following:
- Read extended test kit instructions that you linked me to (Extended Test Kit Directions Archives)
- Do final quick flocc vacuum. It appears that safe for a tiny yellow patch, I got the bulk of it.
- Prep to begin SLAM tomorrow?
Let me know if there are SLAM instructions anywhere. I watched a video on it last night but it was moving a bit quick. I think one thing that had me raising my hand was them mentioning your total pH(?) needs to be X before you start - which I understand, but I don't understand how I'd raise/lower it if that was needed. Hopefully any posted instructions will address.
Looking forward to hearing your advice on next steps - as usual, thank you for your help.
Still doing 5pmm daily adds of liquid chlorine.
No, rock solid, generally, we have made some recent changes and there are a few outstanding.Ok- going to run that test now. Is that app glitchy? I've entered the numbers multiple times and some times it's showing 10 for target FC and other it's showing 14. Numbers are all the same. Regardless, doing FC test now.
