I am clueless, please help
nantucker22
Active member
Jun 18, 2020
33
Phoenixville PA
So after a Long two months out pool is finally up and filled. I want to add checmicals and from what I read, right now I should be concerned with chlorine, PH, CYA? I tested my water (I think) and for zero for chlorine, 6.8 for pH, and CYA- the black dot never disappeared and I tried twice. I paid for the app but why am I so confused???
ajw22
19,460
Northern NJ
Have you bought stabilizer to add CYA to the water?
Have you bought liquid chlorine to add to the water?
What is your TA? Best way to raise pH is to aerate the pool.
nantucker22
Active member
Jun 18, 2020
33
Phoenixville PA
I have all of those things purchased and Ill check my TA now. it is 160
ajw22
19,460
Northern NJ
With a TA of 160 aeration will raise your pH fairly quickly. Even get your kids splashing a lot in the water.
You have the chemicals for stabilizer and chlorine. Use PoolMath to calculate the doses.
Add the stabilizer using the sock method not poured into your skimmer.
nantucker22
Active member
Jun 18, 2020
33
Phoenixville PA
perfect as that is what I just did :) Can we swim? I'm assuming it is safe and I believe after we get out, we should add another 1/2 gallon liquid chlorine. Should i retest tonight or wait until tomorrow? THANK YOU so much for your help
ajw22
19,460
Northern NJ
Sure... go swim :paddle:
Test often as you want. Add chlorine when necessary to keep the FC around your target level. In time you will learn your pool and see when the FC level was correct and testing was not needed. Test your FC and pH at least once a day. You can test anytime it is convenient for you.
nantucker22
Active member
Jun 18, 2020
33
Phoenixville PA
I appreciate all of your help...and we decided to take our first swim...it was amazing :)
Reactions: caligrl2 and Oly
