LorenY67
I hope this is the right place to seek advice. How do I maintain a 10,000 gal pool due to power outage? I got hammered by the eye of Hurricane Ian. I will have my hands full due to power outages that will last days or weeks.
Thanks for replying. I do have a Taylor K2005 test kit. Do you know for starters about how much chlorine is added daily to 10,000 gal pool?Welcome to the forum.
Safety first. Pool can be managed later. If all else is safe, then add chlorine and mix it in with Pool brush, paddle, etc. Do you have a test kit?
Understood, but you must know your CYA to know what level your FC should be maintained at. Likely you were never taught that if you have relied on pool stores and/or a pool builder/maintenance company.I don’t remember the last time I tested the CYA. I’m rather new at this and have only really ever tested FC,TC,PH and TA.
Understood. Thank you kindly for helping me get on the right track. Time for much needed rest. Ian is finally letting up.Understood, but you must know your CYA to know what level your FC should be maintained at. Likely you were never taught that if you have relied on pool stores and/or a pool builder/maintenance company.
Read Pool Care Basics
There is absolutely a value. It will be very effective if your other priorities allow some effort devoted to the pool.Is there any value in adding chlorine without any circulation to attempt and stop algae growth?
@Newdude, TY.There is absolutely a value. It will be very effective if your other priorities allow some effort devoted to the pool.
With no circulation, some/most will settle on the floor as chlorone is heavier than water. Your pool will be easy to brush to mix it around. A couple passes will work wonders and only take a few minutes.
I'd SLAM the best you can with no power. Even though you can't filter out the dead algae, it's way better than exponentially growing algae until the power comes on.
If you have more pressing matters, we can always fix it after too.
Keep us posted.
I have enough chlorine to start a SLAM.
Should I also test levels after brushing for pH and TA and adjust?
Everything else (Salt, CH, CYA) were in balance prior to storm, and pool did not overflow. Just very full.
Will test levels be accurate for pH and TA without full circulation? Brush, test, and assume enough circulation for a valid test?
TY! Will test CYA, then focus on pH and FC for now after stirring up the pool.Do you have enough chlorine or able to get enough liquid chlorine to finish a SLAM?
I would not be so quick to start a SLAM Process. You are not going to be swimming in the pool for a while.
I would use the liquid chlorine you have and maintain a FC level to keep algae tamed. You don't know how long you will need to stretch the supply you have at hand.
Once you have power restored and the house habitable then you can do a SLAM Process to get the pool swimable.
I would not worry about TA. Just keep pH in the 7's.
Test your CYA. You may have got more dilution then you think. Then use that CYA to set your FC level.
Salt and CH does not matter now.
If you get any real out of wack test results then stop. You may have stratification of the fresh rain water on top of the pool water. You may need to churn the pool to get a good mix of the water.
If you can, safely, then it's probably a good idea with no end in sight.Do I need to go out there when the strong gusts die down a bit and drain some water out?
Just got back in, let the water drop back down about 3". Will check on it again in the morning when there is some daylight. Also emptied all my skimmer baskets that were already nearly full.If you can, safely, then it's probably a good idea with no end in sight.
