curious - what is the benefit of your Rebel cleaner over others, why did you take the efforts to convert to suction cleaner vs. a robot like Dolphin? is it much better than the Polaris 280?
My booster pump was failing, and I wanted to eliminate it. Plus the 280 was spraying everything in sight with its stupid tail. I really hated that vac. The Rebel was recommended by the installer of all my other Pentair gear, I didn't research it. It works at least as well as the 280 did, with none of its disadvantages, the list of which is included in what I don't like about robots.
Without ever owning one, I concede that a robot will likely clean a pool better, because it brushes the finish. Vacs don't do that. But that's the only advantage I'll concede to a robot. Off the top of my head:
- Robots are heavy and I don't want to haul one out of the pool when swimmers are in, and certainly not everyday as recommended by some of the manufacturers.
- While it's true you see the hose of a vac floating in the water, that doesn't bug me much at all, but a thick cord laying on the deck is unacceptable to me.
- I don't care how safe they are, I don't want an electrical cord running into the water.
- I don't have to haul out my vac to clean a little bag or filter every few days. My pool is relatively clean, so I can ignore my vac for the entire off season. I don't have to take it in and out, I don't have to clean it, and since I only have to clean my filter once a year, what my vac sends to it is a non-issue. I do have to clean out the pump basket, where the vac sends leaves and such, but that is a simple task, and one that doesn't get me wet. During the winter months, I don't have to do even that. It's just so low maintenance.
- Others will claim robots use less electricity, because you don't need to run the pump. This, too, is a non-issue for me. My vac cycle is part of my filter runtime, so it requires no additional electricity to run. So for my use case the opposite is true, a robot would use more electricity.
- A robot is certainly more expensive and has more things that can go wrong with it, requiring more expensive repairs (this is a presumption on my part). In five years I've spent only the initial cost on my vac, and nothing more.
For me and my pool, a suction vac is the best system. Others will find a robot is superior for them and their pool.
