Problem
I want to vary how the normal "Pool" mode pumps water between pool and spa in an automated fashion. I have a manual valve right now that allows me to configure this. When in pool mode... If the valve is open, it pushes water to both the pool and the spa. If the valve is closed, it pushes water only to the pool. (Note, I have an EasyTouch 8.)
Why I Want This
I want better control because of the following reasons:
Possible Solution
This is where I'm looking for advice and help. One option I'm considering is adding an automated valve to the red circled section in the attached pic. I'm not a plumber, so I'm not sure I'd want to try to do this myself; and to that point, I don't know if this is a bad idea. So, here are my questions:
Any advice here is greatly appreciated!
Why I Want This
- I want more force in the water flow of the pool when adding chemicals.
- I want more force in the water flow of the pool for cleaning purposes.
- I want to reduce the amount of aeration by not having water constantly spill over into the pool when running the pump.
Possible Solution
- I have one open Aux slot in my EasyTouch 8--can I use this to turn an automated valve on/off?
- Can I add an automated valve without eating up that last Aux slot? (I'm pretty sure the answer to this is "no," but maybe I'm wrong?)
- Any ideas as to how much it would cost have a plumber/pool tech replace the backflow and valve?
- For hooking up to the EasyTouch, is it as simple as running the wire to the last Aux terminal and wiring up, and I'm done?
- Is this a bad idea for any reason?
- Is there a better way to do this?
