How Clear is TFP Clear? Let's See (Pics Only Please).
I hope you got a refund from the pool service since they gave you a green pool 🤨👎🏻 .
Maybe you should bill them for failure....
Pink Fail GIF by Jacqueline Jing Lin
Reactions: newdude
A friends daughter lost the back of here ear ring the other day & I could see it while standing on the deck! Thanks TFP!
Isn't it great! You won't get to see that with pool stores throwing :poop: at you like here try this n try that!
Here is my clear TFP pool. A young teenage guest said, WHOAAAAA!!! I've never swam in a clearer pool than this one! The water clarity is so crystal clear! I did a lil fist bump into the air! I absolutely love the way this pool looks on a cloudy day. Storm grey gives a nice deep blue color. I get a lot of compliments on the pool from local neighbors. They yell from the road how beautiful the pool is. LOL
Is it the clearest, most sparkly water you've ever seen? Maybe not. But hear me out... This is day 12 without filtration. The pump repair guy wont be here for 5 more days. I was certain I'd be the proud owner of a scenic swamp when I learned I'd be without a pump for more than 2 weeks. I combed through the forums and as usual, found a solution. Daily testing, liquid chlorine, combined with a through brushing after addition. I can't believe it. So grateful for this forum. Thanks! 20220715_134510.jpg
Add
Is it the clearest, most sparkly water you've ever seen? Maybe not. But hear me out... This is day 12 without filtration. The pump repair guy wont be here for 5 more days. I was certain I'd be the proud owner of a scenic swamp when I learned I'd be without a pump for more than 2 weeks. I combed through the forums and as usual, found a solution. Daily testing, liquid chlorine, combined with a through brushing after addition. I can't believe it. So grateful for this forum. Thanks! View attachment 436354
You can add the chlorine and drop a submersible pump in there for a few hours to mix it well, will also work.
Reactions: Elle Oh
That looks pretty darn clear period, let alone not having circulation. Until I came here I never considered a submersible pump as a quick fix. However I now keep pump parts and a spare motor on hand just in case :)
