Maybe you should bill them for failure....I hope you got a refund from the pool service since they gave you a green pool.
Isn't it great! You won't get to see that with pool stores throwingA friends daughter lost the back of here ear ring the other day & I could see it while standing on the deck! Thanks TFP!
*Pool-aid.4 months drinking the TFP koolaid!
You can add the chlorine and drop a submersible pump in there for a few hours to mix it well, will also work.Is it the clearest, most sparkly water you've ever seen? Maybe not. But hear me out... This is day 12 without filtration. The pump repair guy wont be here for 5 more days. I was certain I'd be the proud owner of a scenic swamp when I learned I'd be without a pump for more than 2 weeks. I combed through the forums and as usual, found a solution. Daily testing, liquid chlorine, combined with a through brushing after addition. I can't believe it. So grateful for this forum. Thanks! View attachment 436354
That looks pretty darn clear period, let alone not having circulation. Until I came here I never considered a submersible pump as a quick fix. However I now keep pump parts and a spare motor on hand just in caseIs it the clearest, most sparkly water you've ever seen? Maybe not. But hear me out... This is day 12 without filtration. The pump repair guy wont be here for 5 more days. I was certain I'd be the proud owner of a scenic swamp when I learned I'd be without a pump for more than 2 weeks. I combed through the forums and as usual, found a solution. Daily testing, liquid chlorine, combined with a through brushing after addition. I can't believe it. So grateful for this forum. Thanks! View attachment 436354
Time to chillSLAM is officially over!!
I think your cleaner has been drinking.I think it looks pretty clear!
