High pH As SLAM Is Nearing Completion
ghall6292
277
North Central PA
I have now had over 20 hours of very clear water and my FC is slowly beginning to drop from where I began. I accidentally added a higher than recommended amount of chlorine (25 ppm) to begin, so I am now just beginning to approach (21 ppm) my SLAM target of 20. I had lowered my pH to 7.4 prior to starting, but now it is at 8.0 again. Should I add more MA to lower my pH again, or is it safe to wait out the chlorine drop? Other than starting out with too high a dose of FC, everything is going without incident. Thanks!
The pH test is invalid when the FC is above 10. Ignore your pH until your FC gets below 10.
