Not just getting started, but my first experience with a somewhat high maintenance pool.
My Pool consists of a fairly large Spa overflowing into the pool via a stream/waterfalls. The pool is not much bigger than the spa. The entire setup is 11K Gallons. So a fairly large surface area and when ever we use the hot tub, a significant portion of the entire water mass is heated. I live in AZ, so we don't heat it right now, but when we moved here a couple of months ago the kids thought it was fun, but it quickly became an algae nightmare and the previous owner hadn't changed the water in probably 6 years, so it was super hard and unmanageable, so I had to empty and Chlorine wash it.
I have a variable speed pump for filtration/cleaning and run it 3 hours during the night for cleaning 2900RPM/70GPM and during the day I run it low speed 8 hours 1400 RPM/30GPM for filtration and to have the stream going.
I have it under control at the moment, but wanted to hear if anybody has recommendations as to how to manage a pool like that. My biggest problem at the moment is Bird control. They think it's the best bird bath in the State. Hanging foil and using Owls has helped with some of the birds, but not all.
