- Apr 10, 2018
- 6,543
- Plaster
- CircuPool RJ-45 Plus
I like your slide idea Dirk...but you gotta go down first.
With the water we deal with here in the desert, I see a continuous battle of high pH and calcium scale buildup if using the stream.
Hope things work out.
Thanks !Just dropping by to say your pool is beautiful! Once you’ve TFP-ified it it will be even more amazing.
So its been almost a month since my original post so I have an update with some additional questions.
I have decided to give the current setup a year to see how manageable it is now that I know exactly what is going on thanks to TFP
After cleaning the stream I gave the pool a good slam until it passed the OCLT and since my levels have been stable.
I installed a Stenner pump + 15 gallon tank to ad my chlorine and my pool has been pretty stable using 43 oz 10% Bleach per day. This equates to around 3PPM/day given my 11.000 gallon pool.
Like you guys predicted my PH is climbing as a result of aeration. I have to ad around 50 oz of 14.5% Muriatic Acid on a weekly basis to keep it within target. I am still contemplating wether I should ad a second Stenner to ad the acid or just ad it manually. Its not that much, so definitely manageable, but automation is of course nice. I am also considering lowering my TA to the lower end of the suggested range to limit PH increase. Any idea how much this would affect my acid use?
Here are my current numbers:
FC: 7.0
PH: 7.4
TA: 90
CH: 350
CYA: 70
CSI: 0.06
TEMP: 86
Dirk is the acid dosing man so hopefully he sees this soon. I have an auto acid dosing system but I think the set up is different. Mine has a ph probe which constantly reads the ph level and dispenses sufficient acid from a drum to keep it to set level. I absolutely love it now that it’s working. For the first 7 weeks I was dealing with a faulty probe. Once it was replaced it’s been a dream! I just fill the drum to the specified dilution once every 3 or so weeks.
As for your TA I’m no expert but personally I wouldn’t touch it. It will likely continue to drop with your acid additions anyway. Your csi is great so I wouldn’t mess with what’s not broken. With your ph though you might want to see if it likes a slightly higher level. You might find your acid usage drops right off if you aim for a slightly higher figure like 7.6/7.7. You can plug the numbers into the pool math app and see what it will do to your csi.
