Yes. Will do that tomorrow cHa ha! Of course! Can you add your test kit to your signature?
Great progress!! Congrats!
Use pool math. Enter your log for 0 CYA. Then click CYA on the home screen to figure out how much CYA to add to get to 30ppm. Weigh that out, put it in a sock, tie the sock up and either put it in your skimmer basket, or hang it a foot or two out from a return. Basket is easiest. Let it sit for 1/2 hour, then start squeezing. It's a bit frustrating, but oddly satisfying. If you squeeze for about 1/2 hour, it will all dissolve, or you can squeeze a bit every now and then.I lost a lot over night, but CC didn’t jump. Is this because stabilizer? What now? I tested CYA and I can see my dot plain as day at the 30 mark.
No, you have algae. You will not lose FC overnight because no stabilizer, there was no sun. CYA protects your FC from the sun.I lost a lot over night, but CC didn’t jump. Is this because stabilizer?
We do what we can. SLAM level for you is 12. If you can get the stabilizer soaking before you leave, that would be great. If not, ok. If you can get FC to 12, great. If not, ok. It is all good and you will get there!!!Ok. You can see what I just added and I was getting ready to go add more to bring me up to 10 for slam but based on what you’re saying given that I need to leave for work I think that I will wait to do that until this evening I think you’re saying that is OK and that I can work on stabilizer this evening
Hot Dog. Tonight I can see my stairs, side of the pool and my seats in the deep end. Progress. I’ve made some additions and finally hit 12 FC. My stabilizer from this am is still dissolving, so i am nursing it, but it’s raining and gross so I’ll probably let it sit over night.
i only have 2 small led lights in the pool. The waterfall is a rock, and I will scrub the rock. I can’t get to the inside of it though. I was just going to ask you about PH. I know my Ph is low. But I won’t worry about it yet. I just check FC at 11 and made another addition. Will check and add before bed.Catsup! Focus on just FC for now. Check and replace to 12 every two hours if you can, while you can. I got obsessive and got up every two hours in the night (NOT RECOMMENDED!!!
Ignore any other testing. FC until the pool is crystal clear and no debris.
THEN, and ONLY THEN, we will check CC and do OCLT.
SCRUB SCRUB SCRUB. This is critical!! Brushing breaks the biofilm on algae on the wall that stops chlorine from getting to all the algae. Do you have lights? Algae can hide there. Scrub the lights. Take them out of the niche and scrub the niche and back of the light. Scrub the skimmers. Looked at the pic again, you might want to scrub the water feature.
Potato Chips!
Yeah, the server is in some other time zone (I think pacific), so if you are central subtract 2 hours. LOLThe time log on these pool logs confuse me.
Three criteriaI dosed again, will do again before bed, and then I guess I’m back to the store for more bleach. If tomorrow am I’ve held chlorine and am under .5 Cc I’m done, right? I’m so over this!
