In another thread I was convinced to buy this new SWG for my non-SWG pool: CircuPool CORE35 Saltwater Chlorinator for up to 35000 gallon salt water pools
The problem is my pool plumbing is 2.5". I contacted Circupool about my options and got the following response: "The largest unions we have is for 2” plumbing. You could consider creating a plumbing bypass around the salt system so that excess flow can pass unimpeded, or if you have a large or high-use pool you could consider installing two systems in parallel."
I have no idea how to DIY the first option and the second option isn't going to happen. Surely there has to be a simple way to do this? A coupling of some sort?
Here is a photo of my plumbing:
Thank you
Thank you
