- Jul 9, 2016
- 227
- Vinyl
- Pureline Crystal Pure 60,000
Hello all,
I have decided to add a Raypak 406k NG heater and a PureLine salt system to my pool. This will require me to rearrange my equipment pad, so while I'm waiting on my new products to arrive I wanted to see if anybody has any advice on setting things up.
Currently I have a 1.65hp variable speed pump that I bought new last August pushing my water through a Jandy top mount sand filter. After leaving the sand filter the line splits into two pipes. The main pipe it to the two returns in my pool. The smaller pipe goes to an auxiliary pump that used to run a Polaris pool cleaner. Since I am now using a robotic cleaner this is a good time to remove the auxiliary pump.
So here is my first question. Can I use the power line going to the auxiliary pump to power the new salt system? I'm thinking yes, but since I don't have the salt system in hand yet I'm not sure.
Second question is, what is the order I need to set up my equipment in? I'm thinking Pump > Sand Filter > Heater > SWG > Pool.
Also, I know that I need to add salt to my water and bring my CYA level up for the salt generator. Is there anything else that I need to do or be aware of when adding these two upgrades to my pool?
Thanks everybody for the help.
Major
Major
