Hey there, first post and unfortunately I am suddenly in need to make some decisions.
I have just recently purchased a home with a pool that had been closed for 5 years. I have hired a "pool guy" to get it going again but after a few days of research on this forum I am questioning some of his decisions.
The pool is roughly 20 years old, 35,000 gallons, vinyl lined, Hayward S244T sand filter, Century Centurion B228SE 1HP single speed pump, Century Centurion B668 Booster Pump, using "standard" chlorinating method.
I want to convert to salt water and also update the pump to variable speed. My pool guy wants to install a Hayward Aqua Rite 40000 gallon salt system and he says the existing pump will work fine.
Again my research here makes me believe the 40000 gallon system is to small so I will have to replace the cell more frequently and if any issues arise that might require a boost in chlorine the cell may not be capable of producing it by itself. Is that a wrong conclusion?
The pump while it may work, I would think a VS pump would be the smarter choice.
Here is what I was planning on having him install instead but I am a little leery of the Circupool brand only because I am a complete rookie to pools and I don't see there name pop up a lot. If you guys could share any thoughts that would be greatly appreciated.
Circupool RJ-60 salt system
Circupool Smartflo 3.0 VS pump
The cost of both would be roughly the same as just the Hayward salt system he quoted me.
With this configuration would I still need the booster pump.
I have to make a decision this weekend and I am reading this forum as fast as I can but any help or advice would be appreciated.
