Hi all, first time poster. I've spend a few hours reading through the various threads trying to make sense of everything and I think I know enough to be dangerous but could sue some help.
I'm currently building a 15' x 25', 13,000 gal, outdoor, in-ground concrete pool and I'm trying to decide on what equipment to run and how to run it with an automation system.
My current plans are the below:
- Pump - Pentair IntelliFlo VSF (011056)
- Heater - Mastertemp NG 400K BTU (460736)
- Filter - Pentair Clean & Clear Plus 420 (160301)
- Lights - Pentair Microbrites or CMP Brilliant Wonders 1.5 LED - Colored (3 lights)
- Laminar Deck Jets - Pentair MagicStream (2-4 jets)
- SWG - Pentair IC40
- Intellichem for pH adjustment
- Solar Heating
- Waterslide
- Automatic Pool Cover - Coverstar or Cover Pools
- Single Skimmer
- Robotic cleaner with a dedicated suction line for manual backup cleaning.
- Badu Stream II Swim jets (2 jets)
- Actuated valves for all necessary plumbing lines
- Will an EasyTouch 8 with Screen logic be sufficient for this pool? Or will I need to go up to an IntelliCenter for additional zones?
- Can the easy touch control the lights and laminars individually? Seems like it can only control them per auxiliary circuit they are wired to. So to control them individually, I would need a transformer and relay dedicated to each light or jet I want to control individually?
- Can the swim jets integrate with the EasyTouch?
- Can a pool cover integrate with the EasyTouch?
- Do I need actuated valves for everything or just the waterslide and jets?
