Hello. I just purchased a home that will be an office I am keeping the pool. It was very green and had algae but was only about 2 months and since it was blue the 1st time I saw it.
It needed a new filter. I had a jandy dev 60 filter installed, and they added de. Turned it on etc.
I checked the chemical levels and tried a product called green to clean, shocked it with chlorine, followed instructions etc. Kept filter on and left. About 19-21 hours later I returned to a still green pool. Maybe slightly better. So it didnt work yet.
I backwashed ther filter, and forgot to add de. Did this backwashing multiple times over 3 days. The filter would filter quickly for about 5 minutes then very slowly and the water flow would be minimized. I backflow for 3 min, added the De etc. Now it's still doing the same thing.
I'm assuming I need to take it apart and clean it? Every how often should you have to back wash it? Any other advice? Should I just drain/clean and replace water? Thanks!
