Hi everyone, hoping for some feedback.
I'll try and explain the series of events.
So now I wonder, perhaps, all I needed was to replace the Ignition Furnace Control board and that would let me reconnect to EasyTouch/Pentair App?
I think either way, the membrane was going bad and assumed since the LED screen was intermittent, that needed replacing.
The heater is about 4 years old. So probably don't want to go buy another, but also don't want to just keep throwing parts at it.
Any thoughts? And which component is it that communicates with EasyTouch Panel, the circuit board or Ignition Furnace Control board?
Thank you,
Jeremy
- A month ago, I happen to notice our pool water was in the high 90's deg. The temperature set in the Pentair mobile app was set for 65 deg, but it seemed the heater disconnected from the EasyTouch Panel and was on it's way heating to it's set temperature of 104 deg.
- Due to the weather in Colorado in February (freezing!) I simply manually adjusted the temperature down the heater to 65 deg and figured I'd start messing with it when the weather improves. (Odd thing, I noticed the little flame on my mobile app was always on, regardless if the heater was actually on or not. Normally the little flame only appears when it's actually heating).
- During this same time, and could be completely non related, the membrane buttons seemed to be having trouble as well as the little LED screen seemed to go in and out. (I thought maybe it could be because we have -0 deg temps).
- Due to the LED screen on the heater and the membrane not working too well, I assumed ALL the issues were related to the circuit board and membrane. I ordered a new circuit board and membrane.
- I installed the new board and membrane, turned the power back on, and now nothing kicked on. I don't see any activity in the LED screen, buttons do nothing (tried holding on the SPA button). So now I'm dead in the water. At least before I was getting constant heat out of it. So I attempted to reinstall the old circuit board just to see if maybe my new board was bad. Because at least the old board was able to run the heater.
Thank you,
Jeremy
