- Jun 24, 2021
- 7,637
- Vinyl
- CircuPool RJ-60
You likely have a good chance that you are still harboring algae with CC at 1. Your actions may have cleared the water, but you still harbor algae. Test your FC right after sunset and test in the morning before sunrise.Thanks! Glad everything we did last week seemed to do the trick. I’ll do the other test you recommend and report back. As always appreciate the help and support!
In the meantime, I would read this -->SLAM Process
One may be in your future. Your OCLT will help determine...
Better to check it now, or you will go through the cycle again. You kinda, sorta, not really did a slam. Following the SLAM process, you will be sure that you have no more algae.
