- May 3, 2014
- 62,696
- Fiberglass
- Pentair Intellichlor IC-40
It was pool store TA - adjusted. Real TA was 90 or so.If the TA is actually in the 50’s
What is the point of coming here to ask for advice if you're just going to ignore it?They did sell me algaecide and alkalinity up and NoPhos (which I already had). I didn’t buy anything else. So I added those three things when I got home.
Oh - missed the asterisk! Even worse then…It was pool store TA - adjusted. Real TA was 90 or so.
AwesomeIf the TA is actually in the 50’s, you may have taken a good spot and introduced pH drift. You’ll then need to buy MA to correct for that..
The three things you bought were about the same as throwing that cash out the window on the highway! It did you that much good!
Have you been using your inline chlorinator and feeding pucks to your pool all this time? If so, this didn't happen out of nowhere.Well, after an entire summer of a sparkling oasis somehow this happened out of nowhere last week! One day perfect next day like this — I have no idea how it got away so fast.
Where did you get any instruction to do that?I added a second high dose of Clorox bleach (10 jugs equaling 1210 oz which is same as the first dose last night so now I’m up to a running total of 2420 oz thus far).
Hmm. When I used PoolMath app yesterday to calculate how much I needed to start SLAM with the numbers Leslie’s gave me (I know it may not be most accurate but all I have until the kit arrives) it said if using 7.5% sodium hypochlorite that I needed to add that much to raise it up. I was under the impression household bleach is ok to use until my liquid chlorine also arrives.Where did you get any instruction to do that?
Clorox is not good to be used as it has additives.
Let's assume it is 6% sodium hypochlorite. That was 25 ppm of FC at once. Without knowledge of what your CYA is, that can damage your liner. You should be adding 5 ppm FC per DAY.
Sure. I’ll hold off doing anything more until both the kit and my liquid chlorine arrives. Was just trying to keep things at bay until then. Thanks.Casey,
It's understandable that your want to get on with things but that's not how TFP works. You need reliable test results from the test kit you ordered. If you don't you can do damage to your liner as Marty pointed out and/or make things worse or just waste a lot of chemicals because you may need a water exchange before you do anything. I have no idea what your test results will give you but I can almost guarantee they will be different than the pool store. I know it's hard with a messed up pool looking at you every day but please do follow Marty's advice. Post a full set of test results as soon as you can after you get your kit. Then you'll be off to the races!
Chris
That's a great decision. What you do with your pool is of course your call. We just hate do see people with the best of intentions make things worse. Do remember also that I believe he recommended 5 ppm FC daily until you get your test results posted.Sure. I’ll hold off doing anything more until both the kit and my liquid chlorine arrives. Was just trying to keep things at bay until then. Thanks.
Casey, First pool for me. Pool store took me for over $1300 in UV Filters, clarifiers, phosphate removers, you name it. Hence my username.Sure. I’ll hold off doing anything more until both the kit and my liquid chlorine arrives. Was just trying to keep things at bay until then. Thanks.
I was literally typing up as we speak. Kit took a little bit longer to arrive than expected so just received today and here’s the results plus a photo. Really looking great again visually and can you tell me how these numbers look?@caseyrichards Any updates?
The FC is good for CYA of 50. The CC at one is concerning at 1, it may mean you have organics/algae. Why don't you do an OCLT, then we will know if you need to slam to remove organics. Overnight Chlorine Loss TestI was literally typing up as we speak. Kit took a little bit longer to arrive than expected so just received today and here’s the results plus a photo. Really looking great again visually and can you tell me how these numbers look?
Test Results 08-28-2021 @ 11:41 AM
Free Chlorine: 8.0
Combined Chlorine: 1.0
pH: 7.5
Total Alkalinity: 250
Calcium Hardness: 350
CYA: 50
Temperature: 85°F
CSI: 0.47
